Z2 DVI HDCP only?
Discussion in 'Projectors, Screens & Video Processors' started by deere, Nov 24, 2004.
  1. deere
    deere
    Nov 13, 2004
    hi,
    Can anyone advise if the Sanyo Z2 DVI socket only accepts HDCP material or will it display non HDCP material via DVI-D cable?
    I have a Centrestage CS1 (DVI but not HDCP)connected to my Z2 via DVI-D but get no picture.
    thanks
  2. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    DVI sockets that are HDCP compliant should work fine with non HDCP sources as not all source material is incrypted anyway. If it doesn't work then it's a configuration issue or an EDID communication issue between the boxes, not HDCP.
    Gordon
  3. Phwed
    Phwed
    Nov 3, 2004
    Can absolutely confirm it since I received my DVI-D cable last night and was messing around with my PC.
    Did you go into the "input 2" settings and change it to DVI/HDCP? By default it is looking for an analogue RGB signal.
  4. BestGear
    BestGear
    Oct 22, 2003
    1,158
    +30
    ...I think the Z2 needs a specific firmware version or later to support HDCP....
    Worth a search to confirm...
    D
