Z2, Denon 1910 and cabling query
Discussion in 'Projectors, Screens & Video Processors' started by Such, Oct 10, 2004.
  1. Such
    Such
    Dec 27, 2003
    2,254
    63
    Greenhithe
    +121
    I've just put up my ceiling mount (from LMP) and am waiting the delivery of the denon. I need to make up a 10m mains lead for the Z2 but cannot find a "C5" plug anywhere, not even at maplin. Can anyone suggest a retailer for this as I am reluctant to chop the cable.
    Also, I will be running this in trunking with a supra dvi-d cable 8m, which I know is not the done thing. Has anyone had experience of running a dvi-d cable close to a mains lead and will it cause interference? Would wrapping either cable in foil help to reduce any interference? - just an idea!
  2. ZippyCat
    ZippyCat
    Aug 9, 2004
    573
    28
    +22
    Try this link:
    http://www.powertraveller.com/acatalog/Power.html
    I’ve bought a couple of these myself. Then all you would need to do is buy a standard kettle connector, plug and cable from ‘Maplins’, ‘CPC’, ‘RS’ etc.
    Hope this helps
    P.S. What a great forum!!! :smashin:
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I use a 9m BetterCables DVI->DVI and it's alongside the power cable to my HCPC for most of its' run and there's no discernable problem that I can see.
    If in doubt you could always go for a fibre-optic cable. :D
  4. Such
    Such
    Dec 27, 2003
    2,254
    63
    Greenhithe
    +121
    Thanks.
    I've sent an email to powertraveller to see how much they would charge to make up a 10m C5 mains lead.
    If its too much, I'll settle for the adapter and DIY.
    Thanks again
