z2 connect to pc for gaming?
Discussion in 'Projectors, Screens & Video Processors' started by jamiev, May 22, 2004.
  1. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    how can i connect the z2 to my pc for gaming?
    what connection?
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    The Z2 has a DVI-I port - using a DVI-I to VGA adaptor will turn this into a VGA port. You will then just need a normal male-male VGA lead to run from PC to projector. I don't think Sanyo have an official adaptor yet but you can pick them up from maplins, CPC and PC shops...
  3. Kramer
    Kramer
    Or run DVI straight to the PJ if your graphics card has a DVI output (nearly all now do nowadays).
    If getting a DVI/VGA adapter, make sure it's for VGA to DVI as most are for DVI to VGA.
    :smoke:
  4. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,522
    Kent
    +830
    There's no need to worry VGA-DVI would be the same as DVI-VGA...
    (you can also get VGA->DVI-I leads btw)
  5. Kramer
    Kramer
    I don't think the adapters or leads are reversible though.....but I may be wrong :)
  6. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,522
    Kent
    +830
    There are only one set of pins for R, G, B, H, V and ground in a DVI-I or 15 pin sub-D socket so I would assume direction is irrelevant (although what's that they say about assumption!?!?!?). Same princible as VGA -> 3 RCA being identical cable to 3 RCA -> VGA...
