Z2: comparison of composite, Svid, componant and RGB Scart to VGA - Screenshot link
Discussion in 'Projectors, Screens & Video Processors' started by nunew33, Dec 12, 2003.
  1. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    I have taken some pics of the same screen comparing Compostie Svid and componant.
    Used avia test card with sony menu (projector still not callibrated
    Source is 735 Sony DVD
    for the scart RGB I had turn stop DVD and couldnt get test card in same pos, so image not quite same.
    All photos taken with same camera settings.
    Pics largeish whole site about half a meg
    Hope its useful to those thinking of getting Keene RGBs scart and wanting to see difference.
    http://www.williamnunez.com/AV/Compare.htm
  2. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    Good work mate.
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,085
    UK.
    +2,578
    Yep - good job!
    Pics of movie screenshots don't often give a true picture, but those examples undeniably work well at showing the differences - composite is obviously the worst.
    Would you say the same image comparisons are evident with movies? I wonder if the component/scart/vga inputs can be identified easily just by viwing a movie.
    Gary.
  4. markbro
    markbro
    Sep 25, 2003
    56
    Co. Limerick, Ireland
    nunew33, Thanks for the info. Rgb looks much sharper than Svideo, even looks better than component IMO. Ordered cables from Keene this morning, so fingers crossed!
  5. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    composite is worst in movies. Im not fussy either but there is a real step change from composite to any of the others. I dont think I could tell the difference between the other three in a movie, but Im not an expert and the proj is still at out of the box settings. Im sure with tweaking they may improve.
  6. Phil White
    Phil White
    Great work nunew!
    The difference betwen RGB and Component looks marginal. I'm using component for DVD's at the moment plus S Video for the Sky Box. What's you experience of Sky thro' RGB? I've seen other anoraks suggest that the slightly softened s video is actually preferable for Sky! And fiinally, what cable are yoiu using for RGB to DVI?
  7. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Phil. I have a panny digibox so svideo is not an option.
    Also the digibox RGB doesnt work. I am swapping for a grundig next week. So my experience is...non existant. It simply doesnt work.
    My cable is a DVI to VGA at the projector end. A 10mVGA run to the source. An RGBs VGA to scart from keene. I have tested the VGA with a laptop and tested the scart with the dvd. The telly struggles to lock onto te rgb from the digibix so Im pretty certain the cabling is fine and the digibox is crud.
  8. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Update: Swapoped Panny for grundig. RGBs fine now. Have added bnefit of Svideo should I need to add anything else.
    Also, done comparison shots for Sky with composite, Svid and Sky
    Pictures larger (1.7meg in total) so you can see RGBs and Svideo differences, not much in it. All photos at 2.8 1/8
    http://www.williamnunez.com/AV/new_page_1.htm
  9. buns
    buns
    Apr 29, 2001
    6,094
    58
    Belfast
    I was looking at the svideo last night..... it gives high freq noise! :eek:
    ad
  10. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Ive yet to watch anything more than childrens programs!!!!
    Got some funny effects in svid in fast moving scenes.
    Sticking to RGBsVGA for skyand componant for DVD. Composite for the VCR
