B
bergsey
I know there's been a lot of posts re DIY ceiling mounts.
Looking at making something simple up out of some steel tubing / plates for my Z2. Given the amount of tweaking you can do via the lense shift, do you see any reasons to bother buying / building a ceiling mount that has all of the adjustable tilt settings etc ?
The only thing I can think of is getting the drop right and setting everything up square to the screen - minor tweaking then via the lense shift.
