Z2 and PAL progressive
Discussion in 'Projectors, Screens & Video Processors' started by cosmo65, Jan 20, 2004.
  1. cosmo65
    cosmo65
    Hi I wonder if anyone can help me with my Z2 problem.
    I have had a Z2 for a month now and one huge issue I have is that whilst watching a film in PAL progressive from my Philips Q50 I seem to get a distinct purple edge on the right hand side of faces. I have tried a mates Harman Kardon DV2550(S) Multi Region DVD Player as well but this also gives the same results in PAL progressive. Have any other Z2 owners experienced this? Although the projector seems fine while watching a region 1 NTSC film in progressive I really can’t see any reason why I shouldn’t expect the same results while watching a PAL disc. Can this problem be sorted or should I return this machine as faulty?.
    Thanks,
    Cosmo..
  2. Jimbobgod
    Jimbobgod
    Feb 23, 2003
    St Albans
    I'm using Z2 with a Sony NVP-NS930, and I've not noticed any similar problems on either PAL or NTSC progressive settings.
