Z2 and keystone
Discussion in 'Projectors, Screens & Video Processors' started by Bonzaimaster, Jul 14, 2004.
  1. Bonzaimaster
    Bonzaimaster
    Feb 8, 2002
    182
    16
    London
    I've recently bought a Sanyo Z2 and am having problems with keystone settings. Whenever I select the keystone setting, I only get a exclamation amrk displayed in the bootom let of the image. I have tried this with S-Video as well as a component connection.
    How can I ebable the keystone settings?
  2. bass007
    bass007
    Apr 8, 2004
    1,514
    london
    +36
    I think it depends on the zoom function..I think if you set it normal through you should be able to do it, if I'm not mistaken
  3. Bonzaimaster
    Bonzaimaster
    Feb 8, 2002
    182
    16
    London
    That's exactly what it was.
    Thanks for your help.
  4. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Wow you need to use Keystone with Lense shift.......
