Z2 and Convergence?
Discussion in 'Projectors, Screens & Video Processors' started by Such, Jan 12, 2005.
  1. Such
    Such
    Dec 27, 2003
    2,235
    63
    Greenhithe
    +115
    When viewing text projected by my Z2, there is a noticeable red outline, similar to that on RPTV's when the convergence is slightly out.
    Is there a setting within the service menu to tweak this out?
    Also, the vertical banding is quite prominent - is there a way to minimise this?
    Any tweaks via the service menu would be most welcome as I feel i should be getting a better pic especially with a panny s97 via dvi.
  2. Such
    Such
    Dec 27, 2003
    2,235
    63
    Greenhithe
    +115
    I must be the only Z2 owner with this problem.
  3. BestGear
    BestGear
    Oct 22, 2003
    1,215
    +42
    Have you just noticed these things or have they been there for a while?
    Do you have a copy of Avia or DVE to test the convergence?
    I would suggest looking for BUNS's earlier Z2 contributions, but since the incident, they have been removed... sadly.
    D
  4. paulw77
    paulw77
    Nov 18, 2000
    578
    28
    Wigan
    +43
    There are ways to get rid of the VB in the service menus - do a search - you will find plenty of info.
  5. Such
    Such
    Dec 27, 2003
    2,235
    63
    Greenhithe
    +115
    djblack - What incident are you referring to?
    I cannot find any info when searching for service menu tweaks. has this been removed too?
  6. Such
    Such
    Dec 27, 2003
    2,235
    63
    Greenhithe
    +115
    These have been there for a while. I have the AVIA test disc but got a bit confused as there was no testing for Gamma, red,blue or green adjustments or colour temp - I think.
