Just thought I'd share with you my experiences with trying to get a long (10m) DVI cable that worked with my Z2.
First off I tried a generic one but that was totally unwatchable - but at least I got a visible picture.
I therefore decided to gamble on one of the expensive ones, considered the bettercable design but I think I remembered zAndy1 having problems a while back. Did a web search for dvi cables & discovered Cobalt Cables in the US, anyway long story short took the plunge & ordered last week.
Well arrived today - 1st impressions was that this was a big diameter cable for DVI-D only (dual link) & so flexibility is a bit of an issue (I had to move the rear PJ mount support off centre to accomodate). Fingers crossed, fired up the PC & selected 1280x720, WOW is all I can say (compared to component out non-prog from Pio 515). This cable is a winner, no picture drop-outs what so ever. I can thoroughly recommend them - email response to queries was next day. They also have money back guarantee, so you just pay shipping. But from my experience you won't be sending it back.
link here..
http://www.cobaltcable.com/product/dvi_cable.htm?source=adwords
There is a 10% off coupon deal too !
BTW, this was my first attempt at HCPC, thanks to those that struggled with getting 1:1 mapping working
. For info I used the Rage 3D tweaker to add 1280x720, set Z2 to HDCP (AV) & everything hooked up like clockwork
link here..
