Z1 rear clearance
Discussion in 'Projectors, Screens & Video Processors' started by markrushton, Feb 3, 2003.
  1. markrushton
    markrushton
    Jan 5, 2003
    49
    Shropshire
    Hi Guy's
    I placed my z1 approx 20 cm from the rear wall, on a stand so that there is free flow of air upwards. The manual only stated that do not place objects near front intakes. I have had it running for approx 30 hrs with no speed up of the fans. My question is, am I taking a chance on internal heat build up that could damage it or would the fans increase in speed before any damage occured?
    thanks
    mark
  2. Smurfin
    Smurfin
    Aug 13, 2002
    21,421
    +4,349
    If you've had no fan speed up then I wouldn't worry.
    I have my Z1 in a case suspended from the ceiling - the rear is open but the sides of the case only allow 5cm gap either side of the PJ: been running for 150 hours now, and not a single occurence of fan speed up in that time.
