Z1 problems
Discussion in 'Projectors, Screens & Video Processors' started by MAW, Dec 8, 2003.
  1. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    My mate's Z1 turned itself off over the w/e, less than 100 hours. It's not the worst of it unfortunately, it now fairly regularly 'freezes', not accepting a video signal, ie sits there with a blue screen, and with no response to remote commands, or to buttons on the projector. The only recourse is to turn it off at the mains, then turn it on again and restart to get the fan going again. Any similar problems? Don't want to send it back with Xmas approaching, so that's the last resort. Any ideas appreciated.
    Martin
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    a Z1 that did exactly the same things a while back. Returned to the dealer who promptly agreed that it was faulty. Did not buy another Z1 after that as I had three faulty machines in less that two weeks, which got a little silly.
    Send it back?
    Cap:(
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Thanks Captain, funny they said they'd never heard of it before! That's the UK agent... I'll have some more words I think.
  4. Teleport
    Teleport
    Did you try resetting the hardware?
    There's a little button on the case, just press it and voila.
    It's worth a try.
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Been there, done that, Owl are on the case, it will be sorted.
