Z1 - New stuck pixel after servicing?
Discussion in 'Projectors, Screens & Video Processors' started by MaxJapan, Feb 14, 2005.
  1. MaxJapan
    MaxJapan
    Here's one for you. My Z1's been getting all dust blobby as of late, and it's still under warranty, so I took it in for a cleaning. I just got it back from Sanyo this evening, and I am dismayed to see that I now have a stuck blue pixel in the bottom left quarter of the screen.
    Now, I'm under the understanding that stuck pixels are manufacturing defects and don't just "appear" -- so do you think my entire LCD matrix was replaced during servicing?
    Also, if the LCD -was- replaced, do you think I should make a stink (politely) about it? Said pixel is VERRRY DISTRACTING. Grr! Snort! Snarl!
    Thanks in advance for any info.
    Max
  2. beecee
    beecee
    Dec 8, 2003
    2,352
    2
    117
    Kirkcaldy, Fife
    +517
    i am about to send my Z1 in for some power supply problems (i think), and i am a bit scared it comes back with pixel problems....
    give them a call and explane, maybe they will offer to replace it?
    on another note,,,,if possible. (or any other Z1 owners)
    after you power up your Z1 does the red power light flicker for a bit when you push the on button on the top of the pj?
  3. Tempest
    Tempest
    Jan 11, 2002
    8,769
    Horley, Surrey
    +4,543
    Yes, I'd complain though it's only YOUR word it was not there before they did the work on it.
    Yes, then can and DO appear at a later date.
    I have 2 red pixels stuck on, on my Pannnie AE200 and there were no pixel faults for the first 40 or so hours.
    1 appeared just after 40 hours, the second just after 50 hours.
    Strange BOTH red ones............
    Best of luck
  4. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    how much did it cost to get your z1 dust blobs cleaned?
  5. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
    Sly
    If you have dust blobs, clean them yourself, takes about 10 mins.I had about 5 dust blobs within the first 2 weeks with my Z1, after I cleaned it they did not return.
  6. jookster
    jookster
    how do you suggest to clean the dust blobs kbfern?
  7. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
    I have covered this before, do a search for "sanyo cleaning" you should find my post on dust blob removal.
  8. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    Repair shops often do loads of the same model at the same time.
    Unless you open a device up and paint some nail varnish on each module before service, who knows what parts you will get back.
    This is more often a problem with xbox and PS2 chipping services though.
  9. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    yeah i have seen the info on doing this but am a bit worried about making anything worse as i am not lucky with this sort of thing..... :rolleyes:
  10. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
    Sly
    How many dust blobs have you got?, it is really easy to remove them.I am no diy'er but it only took 10-15 mins.Where are you in the west mids, if local I may be able to come over and show you.
  11. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    i have 2 dust blobs both in the top left of picture , 1 faint , 1 bright , both green.
    i am in walsall , are u a local then?
  12. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
    You say the 1 is feint and the other bright,what size are they? and what size screen are you projecting onto?.My screen size is around 120" diagonal and the blobs were feint around 4/5" diameter and were only visible on a black screen.
    As 1 blob is bright are you sure its not a stuck pixel,it would be small though.I live in Wednesfield which dependent on where you live in Walsall is only 3/5 miles away.
  13. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    the screen is about 8 feet diagonal , the blobs are towards the top left of the screen and are about 3 inches in diameter.
    i would have thought looking at the size of your screen and blobs i would say mine are comparable to what you had.
    they are def not stuck pixels , when i say bright i mean one is more noticable then the other but both get on my nerves!
    i live about 5 mins from the town centre just off the broadway.
  14. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
    It sounds like dust blobs,are they only visible on a blank (dark/black) screen.I could pop round and see if we can get rid of them.
    I am up in Scotland this weekend and won't be back till Monday night.Maybe I could come over to you next weekend and show you how to clean the pj.
    You will need to get a can of compressed air as shown in my thread about cleaning.
  15. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    sounds good m8 (as long as your not a serial killer or something!) i will probally be at work in the day time but evenings are np.
    thanks for the offer.
  16. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
    Ok Sly,I promise I will leave my AXE at home.
    Will pm my phone number so we can arrange something for next week.
    regards
  17. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    kool thanks mate.
  18. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    are you still able to do this for me keith?
  19. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
    Hi Sly
    Sorry I have not been in touch, but yes I can still come over and show you how to clean the Pj.When is suitable for you?, pm me your address & phone number and I will call you today.I should be able to come over sometime between tommorow/Tues.
