Z1 lamp question
Discussion in 'Projectors, Screens & Video Processors' started by Sarah T, May 10, 2005.
  1. Sarah T
    Sarah T
    I bought a Sanyo PLV Z1 in July 2004 and the picture has now dimmed to an alarming degree. Is that the normal lifespan for a bulb? It's not used every day by any means. Also wanted to ask the best and cheapest place to get a replacement and is there a switching off technique to prolong the life of the bulb? Thank you!!
    Sarah
  2. oneline
    oneline
    Nov 3, 2002
    32
    St Helens
    This happened to my Z1 and shortly after the bulb just went pop,no warning light either.Got a new one from GM Services Milton Keynes(01908 321103) for £222.
  3. morkys
    morkys
    I am aware of at least one Sanyo Z1's bulb dying in less than one year, at only 550 hours. How many hours does your PJ have?
  4. Sarah T
    Sarah T
    Erm.. This it what it says when you hold in the button.
    Lamp 16 hrs
    Eco 552
    0577 hrs.
    I had a quote for a replacement lamp for 172 pounds incl delivery from the company I bought the pj from which doesn't seem bad.
