P
Pete Delaney
Guys I was not sure if I should post in the cables section or here. As I am asking specifically regarding this model I thought I would start here.....So bearing in mind I am a pj NOOB any suggestions with prices/links would be HUGHLY appreciated. PS don't assume I will understand all the lingo so please keep it simple!
Firstly, I will be watching DVDs with pj table mounted about 10 ft from screen. What cable should I use for best piccy quality? At the moment all I have is a long svid connection which is about 5m long and cost around £20. DVD player (pioneer 525) is located below where the screen will be.
Secondly, will I need filters? If so why, how much and where from?
Finally, I have a PC sitting only 4m from where the pj will be and 4m from my receiver/dvd. The sanyo does not have dvi input but it does have a computer input. Will I get the best pics running from my Athlonxp2600 with Geforce4 TI4200? If so why, and where could I get a cable long enough? I have read a bit on HCPC and 1:1 mapping but I don't really understand it. My sound card is an Audigy 2, could I run 5.1 sound into my sony strdb930 with it and if so how?
Thanks in advance for your patience and I apologise for the barrage of questions, I hope some of you are up for this challenge
Regards
Pete
Regards
Pete
