Z1 and Xbox / Scart
Discussion in 'Projectors, Screens & Video Processors' started by paveypop, Jun 18, 2003.
  1. paveypop
    paveypop
    Hi all
    what is the best solution for connectiing my xbox to my Z1.
    Is it via a VGA lead and if so what type would i use.
    Also there are vga to scart leads out there but which is correct for the Z1
    any info would be of help.
    Regards.
    Dave
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I'm going to assume that a Z1 is not CRT projector.:devil:
    If the projector has a componet input (that's the one with the Red green and blue phono/RCA connectors. Buy a component kit for the Xbox and connect the relative colours together. Very few projectors with a VGA input will like standard video rates into the VGA port as they will be expecting a higher rate signal
  3. paveypop
    paveypop
    The Z1 is the Sanyo PLV-Z1 digital projector
    Sorry for any confussion
    Dave
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Thought so.
    You may have more luck in the LCD, DLP section.
    THEY, moved us here because we go cheeky about lamped projectors.
    Which is totally uncalled for.
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +794
    I hope you mean being moved is uncalled for and not being cheeky about lamped projectors.
    get yourself the component hi-def pack and put the image in via component.
    It is worth getting the machine chipped and using a piece of software called "video mode select". you can then set you machine to ntsc and output in interlaced, 480p, 720p and 1080i.
    Not sure what you projecter handle but I am sure that 480p would be alright and a good improvement.
  6. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    One should never stop being checky about lamped projectors.
  7. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    527
    North Cotswolds
    +3
    Thread moved from CRT Projectors Forum
