YUV to YPbPr problem
Discussion in 'Cables & Switches' started by IronGiant, Sep 29, 2004.
  1. IronGiant
    IronGiant
    Jun 7, 2003
    62,720
    Oxford UK
    +39,894
    My Philips DVD-763SA DVD player can output YUV and my Philips plasma 42PF9945 has YPbPr inputs. I hooked them together with a profigold component lead and the TV says the format is not available? It's supposed to be able to take YPbPr 480p, 576p, 1080i
    Dave
  2. isko
    isko
    Aug 29, 2004
    26
    There must be a menu item of DVD player which will give you a choice of connection type, like component, s-video and scart. You have to adjust it for component connection beforehand.
