YUV to VGA?
AFC
I use a very similar lead to the VGA port on my plasma and it's very good. You can pick these leads up very cheap on eBay, most are overseas suppliers at the moment but postage on these is very reasonable.
shaithis
Very encouraging responses, thanks :)
Now, is anyone using one of these on an LG? Preferably the one I mentioned above.......getting 'cold feet' about the quality of the LG component boards =/
Getting RS to replace mine tonight (VERY PQ on component board inputs) - if its still no good, I will need a solution via the DVI or VGA ports as the PQ through them seem superb (hooked PC up to test).
shaithis
Can confirm these cables do NOT work on the LG i have....
And RS replaced my component board and PQ is still GD aweful through any of the component board inputs.
*depressed*
