YUV to VGA ???
Discussion in 'Cables & Switches' started by jont, Jan 18, 2005.
  1. jont
    jont
    Apr 8, 2002
    4,203
    near Aylesbury
    +528
    Can this be technically done ?
    I have an Arcam AV8 with xbox, sky+(with JS rgb>yuV) and dv27 player attached all feeding YUV into the AV8 that puts out YUV to my v4 panny plasma
    I've got a dvi card that I want to hook my htpc up to so that means I'll have to use the vga socket to take the analogue video out of the AV8 ...
    So what I'm after is an RCA YUV cable to VGA ...
    Or do I have to switch the AV8 to output RGB to go to VGA ... if that is the case am I going to lose the prog scan from mydv27 if I output RGB and does the xbox do RGB on only YUV & composite ?
    cheers
    Jon
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    can get the cable but i dont think the PW4 accepts component via VGA
  3. MAD ANDY
    MAD ANDY
    Nov 12, 2003
    304
    Cheshire
    +9
    http://www.beststuff.co.uk/specialist_rgb_leads.htm
    [​IMG]
    Hama 3 Phono to 15 Pin HD VGA
    Hama 10m 3 Phono Component to VGA lead. To connect devices with 3 Phono out (YUV component) to devices with HDD VGA in. Typical uses would be for connecting a DVD player to a projector, video projector or flat screen TV.
    10 Metre length
    £24.99
  4. jont
    jont
    Apr 8, 2002
    4,203
    near Aylesbury
    +528
    hmmm ... i tried the rgb of an rgbhv>vga cable and got a green screen on the panny even when the screen was set to 'sync on g' ... how can I check that hornyd is deffo right ?
    cheers
    Jon
