YUV to VGA cable query
Discussion in 'Plasma TVs' started by GAmbrose, Jul 16, 2003.
  1. GAmbrose
    GAmbrose
    Jul 5, 2003
    824
    28
    Essex
    +73
    I just purchased a 3 Phone to VGA cable from Lektropacks. Not sure If I have been conned or not.
    I was expecting to recieve this:
    http://www.lektropacks.co.uk/dept.asp?Hash=611&dept_id=32
    (Search code: SS15D3P)
    Which shows a rather funky purple cable with metal interconnects and 15 pins in the VGA plug.
    What they actually sent me was this:
    [​IMG]
    Note the cheap plastic connections and only 6 pins on the vga plug.
    Is it suitable for high quality YUV -> VGA? Should it not have the full 15 pins?
    Regards
    Gary A
  2. dazzer123
    dazzer123
    Sep 30, 2002
    398
    Stoke-On-Trent
    +3
    I considered ordering one of those but I wont now what a shower I would be sending those right back mate.
  3. GAmbrose
    GAmbrose
    Jul 5, 2003
    824
    28
    Essex
    +73
    Thats what I'm thinking.
    But often you don't actually need all the pins, just wondered if their were any experts here who would know if a YUV -> VGA cable would usually make use of all 15 pins?
    Gary A
  4. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    A bit off-topic, but I don't use these lot any more. My last order involved them emailing all my personal details, credit card info (including the 3 digit validation code), address, etc around the internet for all to see. They blamed their order processing company, never gave me an apology or offered me any compensation. I had to cancel the card on advice from the card company.
    Was very unimpressed!
    EffTee
  5. jmack
    jmack
    vandamme vga leads only have 14 pins ,john sim did explain them all to me once but dammed if i can remember.
  6. GAmbrose
    GAmbrose
    Jul 5, 2003
    824
    28
    Essex
    +73
    They were quick, and the 3x phono to 3x phono YUV cable they sent me does appear to be high quality.
    But that VGA thing just looks shoddy to me. Funnily enough the T&C's on their invoice say:
    "Unless otherwise confirmed. Nothing in our catalogue or advertising is to be taken as a representation of the source or original manufacture of production of the goods or any part thereof."
    Gary A
  7. GAmbrose
    GAmbrose
    Jul 5, 2003
    824
    28
    Essex
    +73
    Aha:
    http://www.avforums.com/forums/showthread.php?s=&threadid=59074&highlight=VGA+pin
    "You don't need all 15, infact soldering all 15 is just about impossible !
    RGB HV and their grounds are all you need. The plug and play data pins (monitor ID bits) are not usually needed for a projector, infact maybe best left out, unless you want windows to take control of refresh rates etc when it finds the projector, IMHO."
    Whats HV stand for?
    Gary A
  8. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Horizontal & Vertical
  9. GAmbrose
    GAmbrose
    Jul 5, 2003
    824
    28
    Essex
    +73
    Which this doesn't have wired up.
    It's going back then.
    Gary A
  10. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    It's not a RGB cable though :confused: so H&V are not going to come into it.
    It's YUV to VGA (giving YUV output out through VGA (not RGB output). The cable doesn't convert the signal)
    The problem that causes is that if you have a panel like Panny 5 the VGA only accepts RGB thru VGA in (So this cable would not work)
    But a Panny 6 has a configurable VGA in for either YUV or RGB so it would be OK
    I think that's right.
  11. dazzer123
    dazzer123
    Sep 30, 2002
    398
    Stoke-On-Trent
    +3
    Well gambrose the cable they seem to have sent you look's no better than the one supplied with a product i recently bought and i was considering getting one from lektropaks to replace it, based on the picture on thier website well wot u see certainly is not wot u get i suppose van damme it shall have to be.
  12. rsamdal
    rsamdal
    Feb 9, 2003
    43
    Norway
    Supra have a cable that might be better.
    I got this one from Eltek in Norway today.
    [​IMG]
    Roger
  13. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    I was looking at that cable a few months ago. They told me they had a problem and it wasn't available yet. You only need 6 pins wired for YUV by definition, that's how many connectors there are in the plugs at the other end! As to cheap'n nasty well I'd have to agree! But as you say their other stuff is good, some of it very good. I've used them a lot, but always phoned my order.... Lucky me by the looks of things! Never had any trouble from them, quite the reverse, even the women on the phones know the products completely.
    BTW that supra cable is RGB not YUV!!!!! Will not do the job, different pins will be wired. Vandamme here we go then.
    ...except they don't seem to list one either. What I'd do is get that one copied by a specialist cable maker, I know of one in New Malden, maybe if you put it about here what you are doing, we could all have one and buy you a beer or two, to help pay for the original?
  14. rsamdal
    rsamdal
    Feb 9, 2003
    43
    Norway
    The label on the package is saying VGA to 3 RCA
    Component Video Interconnect Cable.
    This is the pin config for the Supra VGA to 3 RCA:
    Red wire to VGA pin 1 (pin 6 GND)
    Green wire to VGA Pin 2 (pin 7 GND)
    Blue wire to VGA Pin 3 (pin 8 GND
    If it turns out the pin configuration is wrong, I'll have to find my solder iron then :)
    Roger
  15. rsamdal
    rsamdal
    Feb 9, 2003
    43
    Norway
    I've just checked the Supra catalogue.
    The VGA to 3 RCA is listed as a "Component Video" cable.
    Other cables are listed as "RGB + Sync" and "RGB + V/H Sync"
    Check out: http://www.jenving.se/image/cat01-02.pdf
    Page 22
    Roger
  16. GAmbrose
    GAmbrose
    Jul 5, 2003
    824
    28
    Essex
    +73
    I kept it in the end, it actually works fine and gives a stunning picture.
    It just looks tacky.
    Gary A
  17. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,270
    The Borders
    +2,572
    Hello Gary
    There's no way of knowing if the cable you've had delivered is in any way degrading your signal - it sure doesn't look like the cable on the web site; and certainly looks more like the sort of 'freebie' the manufacturers tend to supply..
    We supply VanDamme, Supra and BetterCables - all three of whom offer 3RCA or 3BNC to HD15 wired for YUV.
    The cables used by these manufacturers only have three or possibly four lines so all 15 pins on the HD15 will never be wired.
    Personally I'd send that one back and ask for something of similar quality to the RCA cable you've received.
    Best regards
    Joe
  18. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    You'll find that whether a cable is wired for YUV, RGB, RGBHV or any other type of RGB and sync - the red, green and blue connections will always be the same so any of these cables will work for YUV.
