Yuv - Rgb
Discussion in 'General TV Discussions Forum' started by Jamesdc, Nov 12, 2003.
  1. Jamesdc
    Jamesdc
    howdy all,
    got a small problem here, I need to convert component to rgb....ive only found one external box that will do this (for around $150US)
    has anyone used this kind of converter?
    I want to hook up a US Denon 2900 dvd player to my grundig xentia tv.
    cheers
    James,
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
  3. Jamesdc
    Jamesdc
    oh kds...make that two then (although the kds stuff looks hella more impressive)
    however im a little lost as to the unit (KD-VTCA3)
    it looks like it will only convert vga to YPrPb and a pass through for scart rgb. (and 'Scart compatibilty' doesnt sound to crash hot)
    does it do YPrPb to Scart rgb?
    thanks
    James,
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    They do an Xblaster version and a higher spec unit. They also do a rgb to component one as well.
    You could also look at Gefen products, extron and kramer as other likely candidates
