dagger
Established Member
Can someone please give me some advice.
I have a JVC dvd player which used to be perfect and output in the normal way thru a scart in RGB format.
I then decided to update the player to multiregion with a simple firmware upgrade. - all seemed okay , until I noticed that there was no longer the option of RGB output !!! The picture looks a bit hazy now and not pinsharp like before.
In place of the RGB option in the settings menu I noticed it now says YUV as the main option.
Am I stuffed now or do i just need some component leads or is yuv better than rgb anyway ... aaaaargggghhh I dont know what to do
Please help any comments appreciated
