The JS is coded. Y=Y, this is sync. You must have it right if you have any picture at all. It can't be that hard to get it right with the other 2 surely. Check the scart cable too, if there's a broken wire or the plug not seated, that would do it too, or else is the input set for RGB and not component, that looks truly weird!
