James Thomas 75
Hi everyone.
I've tried several times using the intellibeam mic. to get a decent reading on my Yamaha YSP 2500 sound setup. But I've come to the conclusion that the front area isn't really clear enough for it to obtain an accurate reading in the front left/right department.
With all of the results I've had so far; the dialogue on movies at certain times,is extremely low.
My next port of call is to play around with the front channel beam angles manually,to see what results I get.
Would anyone be so kind as to have a quick look to see what type of angle I should be aiming towards please. As I'm unsure whether they need to be aimed directly at me; or off of the side walls in a similar fashion to the rear channels?
Many thanks in advance.
