YSP-1 owners, advice please
Discussion in 'Home Cinema Speakers' started by Mr_Wistles, Sep 14, 2005.
  1. Mr_Wistles
    Mr_Wistles
    Mar 11, 2004
    12,004
    Essex
    +2,946
    Hello,
    I am thinking of getting a YSP-1 but I am wondering if my room shape is wrong for it.
    ________________________________
    IXXXXXX I
    I I
    I I
    I I
    I I
    I DOOR SOFA I
    _________________________________
    Excuse my crappy drawing. The YSP1 will be facing the door, represented by the X's and I will be on the sofa.
    How do current owners think it will perform? does anyone have it in this configuration already?
    I have not demoed one yet as my room shape may totally negate its effectiveness.
    Also does anyone know if they are currently in stock at Costco's at Lakeside?
    Thanks,
    Russell
    EDIT - The sofa should be about 3/4 along the bottom wall but for some reason it looks okay when I type it but when I post it changes.
  2. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    36,265
    10
    13
    CyberSpace
    +10,767
    The drawing doesn't really help ;-) I have the YSP-800 which is in stock at Costco and has the automated, microphone based, setup built-in.
    A door is not a problem, but I do think you need to keep it closed for the best result. My YSP-800 complains when the Mic is not used directly opposite it, so another consideration would be that you do need to sit opposite the speaker.
    Don't know about the YSP-1 but the 800 has got 3 memories which is usefull. Because drawing the curtains sucked all the bass away, so the solution was to set it up again and store the curtain closed situation in memory 2...
    Hope this helped a little...
