YPbPr to HD15
Discussion in 'Projectors, Screens & Video Processors' started by mivvi, Jul 29, 2003.
  1. mivvi
    mivvi
    Hi all,
    I need to know if I can run the component out from my DVD player, directly to my Plasma which has a 15 pin d-type connector on it. Any help would be great, thanks!
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    What model Sony plasma is it? I can have a look at work today and see if it will.
    PM me later today.
  3. mivvi
    mivvi
    The model is the sony PFM-42B1E. It also has the composite and Y/C input card fitted.
    Thanks!
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    The plasma will take a component YUV signal through either of it's 15pin D-sub inputs. All you need to do is make sure it is accpeting the right signal by pressing the RGB/YUV button on the remote after selecting input 1 or 2.
    Hope this helps.
  5. mivvi
    mivvi
    Thanks Retro!
    Does this mean I can purchase a lead that will run from component out on the DVD player (3xPhono's) to the D-Type on the plasma? I don't need to put it through any special type of convertor box or something?
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    All you require is a cable to take the component signal into the 15pin d-sub.
    The easiest ones of these to find are the 5 BNC to 15pin cables that are designed for RGBHV operation. You simply need to only use the RGB plugs, for the YUV parts and this should work fine.
    You should be able to find a 3 phono to 15pin cables easily though.
  7. mivvi
    mivvi
    I am going to look for a cable now. thanks again, you have been of great help.
  8. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    No problem.
