Davoid
Hello,
I went and used my Yamaha RX-A1030 YPAO to set up my temporary layout till renovations are done (could be a while). After the YPAO ran it's task all my speakers were set at "large" and the subwoofer was set at 40 Hz (80 Hz is default).
My speakers are all Polk Audio - RTi A7 floor standing, CS10 center and PSW110 subwoofer.
I have attached a picture of my current layout. I sit about 2.5m from the TV if this helps.
I had moved the small table out of the way before running the test.
Before the YPAO all speakers were set to "small", should I be changing them back to this?
thanks,
David
thanks,
David
