Youview RF Out
Discussion in 'Freeview & YouView' started by razbox, Feb 23, 2013.
Tags:
  1. razbox
    razbox
    Jul 4, 2006
    701
    London
    +77
    I replaced Sky with BT Youview and found that the RF Out doesn't provide enough of a signal boost so that my bedroom TV use it for Freeview. I activated the RF Loop Through in Settings-Device Management but that made no difference.
    Everything works if I use my Sky box to have the ariel in and RF1 to Youview and RF2 to the bedroom TV.
    But it seems a bit overkill to keep a Sky box switched on just for that - is there a simpler solution?
    PS - I just need Freeview signal in the bedroom, not the Youview signal itself.
    cheers
  2. jonna
    jonna
    Mar 25, 2002
    3,206
    Cheshire
    +2,529
    Your box should be set to Low Eco mode.
  3. razbox
    razbox
    Jul 4, 2006
    701
    London
    +77
    Jonna, thanks for the reply. It is already set in Low Eco.
  4. jonna
    jonna
    Mar 25, 2002
    3,206
    Cheshire
    +2,529
  5. razbox
    razbox
    Jul 4, 2006
    701
    London
    +77
    I tried that search and got nowhere, hence this post
  6. jonna
    jonna
    Mar 25, 2002
    3,206
    Cheshire
    +2,529
    Sorry I can't help, the only thing I would try is to connect the main aerial cable and the 2nd cable together and check your signal upstairs thus eliminating your youview box.
  7. razbox
    razbox
    Jul 4, 2006
    701
    London
    +77
    I tried that and it wouldn't work without the Youview either. So I guess the Sky box has a signal booster in it. Is there a simple box I can buy that will do the same as the Sky box is doing?
    cheers
  8. jonna
    jonna
    Mar 25, 2002
    3,206
    Cheshire
    +2,529
