Youtube
I've just watched a 7 min clip on YT and wanted to take a 10 second bit from the middle of it. Is there any way I can do this?
Singh400
Yeah you can, watch the video again, once it has finished. open your local settings and look for the biggest file (in size) that will be the video that has been downloaded into your cache. Copy this file to your desktop, change it's extension to .flv now all you need to do is find a program that can view/edit flv files.
Cable Monkey
Youtube?
Rygar
If you are going to try and retreive it from cache as suggested by Singh400, it is a good idea to clear out your cache first, as then it will be easier to spot.
You may also want to try Replay AV which has a free trial. It will certainly capture it for you, not sure if it has any editing facilities included though.
http://www.applian.com/replay-av/index.php
