Xbox Live will go on sale in Europe at a cost of 59 euros (£39) and the service will include a headset, so gamers can talk to each other while playing, two games and a 12-month subscription.
Actually, I may have jumped the gun. From what I'm reading, the "official" launch is in March, but from Nov. 30, UK gamers will be able to sign up. Early adopters will probably have to put up with bugs and server downtimes, but your years' membership doesn't start until March, so you're effectively playing for free until then!
i have been wondering whether i can buy a wireless access point give it an ip address on my pc then stick it in the back of the xbox giving me wireless access to my other access point ( which is plugged into my adsl router/modem ) ??????
I wonder what you get with the live package ??
I take it it must be an ethernet cable , and i guess you must have to give you xbox and ip address and a default gateway, does anyone know ??
i know that you can give the xobox an ip address etc. because i have done this with a chip installed.
Why do you need to give your X-Box an IP? Just set up your router with DHCP, this will then assign your X-Box an IP address. As long as you have port forwarding enabled (which I doubt will be a necessity) for any ports that may be needed there should be no problems.
I haven't really looked at the specs mind you but I wouldn't have thought that anything strange would be going on that stops NAT connections working. They would lose half the people who would play on it.
And yes the beta is running first, with up to a 1000 gamers being allowed to take part in each country I believe.
It will actually need two IPs although they can be DHCP.
As the box has a standard network card any form of connection will be okay but remember that "live" will need to connect to your box so NATing will have to be setup carefully.
I think an access point has to have an ip address as it cant obtain one automatically.
i have my router set up with dhcp, with an ip adress of XXX.XXX.XXX.001 then my access point has to have an ip address of XXX.XXX.XXX002 all my wireless network cards are set up to receive an ip address automatically and they get given XXX.XXX.XXX.002 , XXX.XXX.XXX.003 etc.
so i guess if i give the second access point and address in the same range it should be fine.
by its nature a wirelss network card doesnt have a rj45 connection , otherwise you would have to plug your network card into , well er , a network card.
Yes as long as the Xbox knows where the gateway is you shouldn't have a problem although thinking of it it does need to communicate over port 80 so I don't know how that will affect anyone with a domain at home.
