Yet Another Query - last one: Phillips 32PW9616 and Sony DVP-NS900 DVD
Discussion in 'General TV Discussions Forum' started by Milhouse, Nov 10, 2001.
  1. Milhouse
    Milhouse
    This DVD player is connected to SCART 1 with a Dolby Digital co-axial connection for surround sound. The SCART cable is fully connected (although I will be changing to RGB only shortly :) )
    Watching films is great - absolutely no problems at all. However, watching the additional feature material is causing the TV to switch to another source and then back again to SCART #1. It does this once or twice a minute, and each switch takes a couple of seconds.
    The DVD player is not modified in any way, it's brand new too. I've tried it on another TV (a 4:3 portable) and there don't appear to be any switching or screen blanking problems although this is hardly conclusive.
    I have 3 DVD's and all exhibit the problem:
    Making The Matrix (R2, The Matrix);
    Directors Commentary (R2, Gladiator)
    TiVo Demo DVD
    Is it the DVD player at fault or a problem with the TV set? It seems as if SCART #1 is losing control and then reasserting pin 8 (if that makes any sense!) I've only had this happen in the additional material on DVDs - the main movies are fine, 2 hours+ without the source switching once. :confused:
  2. aevans
    aevans
    As you'll see from other posts, I'm getting similar problem (only far worse on some DVD's, Casino for example is totally un-watchable).
    Problem only seems to become apparent when you switch the DVD output to RGB. Can you confirm this is true for your set-up ?
    As it looks like the problem is with the NS900 and not my TV as first thought, I've started a new forum thread under the DVD Players and Recorders section to try and get some more input. Please can you post your findings there.
  3. Milhouse
    Milhouse
    Have just done so - this thread (and mine) may as well be closed.
    New thread in DVD is here.
