Yet Another Newbie Needs Help!
Discussion in 'Home Cinema Buying & Building' started by mikeinsthelens, Dec 1, 2003.
  1. mikeinsthelens
    mikeinsthelens
    Hi Everyone
    I am hoping someone can help me. I have just bought a JVC TH-A35 DVD Digitial Cinema System to accompany my JVC AV32R25 TV and my HR-j695EK video.
    I have connected everything as stated in the manual and the DVD is working brilliantly with all the speakers working fine.
    I am also using SKY and have been told that if I purchase a movie of SKY Box Office, I can use my speakers to recreate Dolby Surround.
    I have tried EVERYTHING but nothing seems to work.
    My DVD player is connected directly to my TV, my Video and Sky are also connected to my TV directly.
    Someone has suggested I need a Optical Digital Cord (?) but even if I had one I wouldnt know where to connect it, I have a port in the back of the DVD player but none in the TV or Video.
    Please help!!:suicide:
  2. mikeinsthelens
    mikeinsthelens
    Can no one help :confused:
  3. ntslik
    ntslik
    Jul 26, 2002
    620
    Cambridgeshire
    +10
    Ok firstly the optical would normally go in to the AV amp/receiver but I assume the JVC unit is a one-box-system, therefore you can't input an optical.
    regarding the sky, do you have sky+, if not then again you won't get digital sound from the JVC unit, you could connect a simple pair of audio leads though and get pro-logic, you shoul dhave a TV or VCR input on the back thats red and white.
    Hope this helps
  4. mikeinsthelens
    mikeinsthelens
    Yes the DVD player is all one unit it has an optical in only. I dont sky+, all I want is pro logic, I have connect the leads to Sky and to my DVD (red and white) but still no sounds comes through. Do I have to disconnect the scart from my DVD to TV to be able to get sound through the DVD?
  5. mikeinsthelens
    mikeinsthelens
    Ever feel like your talking to yourself?? :suicide:
    Anyway I have tried disconnecting the scart lead from my TV to DVD and STILL nothing happens.
    Someone please tellme what I doing wrong.
  6. JimSpriggs
    JimSpriggs
    You might find there is an option or button on your remote to select the sound source, set it to STB or whatever to feed sound from your sky box rather than the DVD
  7. Leebert
    Leebert
    Dec 2, 2003
    Surrey
    Hello
    I have connected mine up using the phono leads (red and black ones) from my sky box to the JVC unit.
    While your watching sky, select 'aux' on your remote. If there is still no noise, press aux again to get the JVC unit to cycle through the inputs.
    I hope this helps.
    PS does yours suffer from a constant low volume hiss from the speakers? Especially noticable when playing a quiet CD at low volume.
    Leebert
  8. mikeinsthelens
    mikeinsthelens
    YES!!! :clap:
    Lol it is working now it comes through the analogue part! Thanks Lee.
    With regards to the other point I cant say I have noticed any hissing from mine, but I have only played really loud CD's.
    Email me if you like and tell me which CD your playing if Ive got it ill try it on mine.
    mikesmethurst@blueyonder.co.uk
  9. shenderson
    shenderson
    I've noticed the hiss on my unit as well. I am giving serious consideration to taking my unit back as once you notice it, its hard to ignore. It's volume independant which is strange and no matter what combination of speakers / wire routes you use it is still there! I've also noticed some 50Hz hum from front left when you crank up the volume and again wire routing and speaker type does not get rid of the problem! Grrrr!
    Anyone else getting such problems with these units?
  10. mikeinsthelens
    mikeinsthelens
    After the above post I played a CD and DID notice a slight hissing from the speakers. However this is only slight and will not cause me a problem.
    I have had no problems with the speakers humming though
