yet another inexpensive projector mount
Discussion in 'Projectors, Screens & Video Processors' started by jasper_mccrea, Jun 20, 2005.
  1. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    882
    London
    +20
    Well, I didn't want to spend a lot to wall mount my projector, so I took a look around at speaker brackets. The Maplin one came in cheapest at £7.99, so I took a chance on that.
    http://www.maplin.co.uk/Module.aspx?ModuleNo=9655&doy=14m6D
    Worked a treat. The holes in the plate line up with two of the holes in the bottom of the AE200 what I got, and the thing is pretty solid. Good enough for me.
  2. spickee
    spickee
    May 8, 2001
    239
    MK
    +5
    Any chance of a hole measurement to see if this would fit my shiny new Z3.
    Ta
  3. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    882
    London
    +20
    Will do that tonight. NP. But if you had a drill, you could make it fit.
  4. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    882
    London
    +20
    The holes are on a 120mm square, and fit an M4 bolt OK. They'd probably fit an M5.
    I have the other one of these, so if it were any good to you, I could send it on for a few quid.
    Jasper
  5. spickee
    spickee
    May 8, 2001
    239
    MK
    +5
    Just trying to decide if I want to trust my new Z3 upside down on a couple of quids worth of bracket.
    I'm sure it would be fine but as it's a new toy I think I'll hold off for now, but thanks for the offer.
