Yet another Cheap DABS 32" LCD
Discussion in 'LCD & LED LCD TVs Forum' started by Xelon, May 20, 2005.
Tags:
  1. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
  2. benwong
    benwong
    Isn't it showing as £699.99?
    Or is £739 including Postage?
    Ben
  3. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Sure enough it has changed to £699, still shows £739 if you go up a level in the listings, a mistake maybe? If it has DVI it would make a good stop gap.
  4. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Have come to the conclusion the the Manufacturers Code: CTT3207W for this DABS Value £699 32" LCD is incorrect, as I've used several search engines and come up with nothing.
  5. benwong
    benwong
    I reckon someone should just bite the bullet and buy one of these TVs, then report the findings on here!!
    I nominate... Xelon!
    Look forward to hearing about it! :smashin:
    Ben
  6. petebrady
    petebrady
  7. cjp123
    cjp123
    Nov 2, 2004
    77
    They are actually made by a company called Teco. I am waiting for the data sheet with the specs
