Yet Another Cheap 32" LCD TV
Discussion in 'LCD & LED LCD TVs' started by Xelon, Dec 21, 2004.
  1. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Branded as Video7\Acer £1049 delivered @ Ebuyer, not a bad spec either, maybe a pricing trend for 2005? See specs below.
    V7 LTV32D
    The silver coloured LTV32D is the new flagship of V7 videoseven. With a panel size of 31.5 inch and a brilliant screen quality he guaranteed a perfect television expierence.
    31.5" LCD Panel (80 cm)
    600:1 Contrast
    500 cd/m² brightness
    18 ms Response time
    176°/176° Viewing Angle H/V
    DVI/VGA
    1366 x 768
    Cable Tuner (Hyperband), Virtual Surround, Sleep/On Timer, PIP-Function (Picture-in-Picture, HDTV ready,Teletext (100 pages), Silver design, wallmountable(VESA 200 mm)and many more...
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Might be a little slow to get rid of all the smearing. Specs don't really say anything about a tv though, the proof is in the pudding !
    Richie.
  3. Nicky
    Nicky
    Nov 5, 2003
    179
    +5
  4. Naqernf
    Naqernf
    Also, it apparently has no RGB on either of the 2 SCART connectors, just plain composite signals. Another reason that put it off of my list...
    (What about that RGB-VGA input for PC or DTV set-top boxes? I assume I wouldn't be able to use a simple Scart-RGB to VGA adapter cable, if such a thing existed?)
  5. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Yup, the specs are decent for the price, but Pixel Response is definitely on the slow side. This set would suit businesses using it for displays at shows or conferences. Bit of a weird one...
    Jimmy
  6. Steviemacca
    Steviemacca
    Anyone actually bought one of these? In the manual it states it can do 720p and 1080i. I know nothing about HDCP/HDTV etc. I take it needs more than this then to be compatible with the SKY HDTV service. Can HDTV connect through component slots or only via HDMI or DVI?
    Sorry if the answers to these are obvious.
    Steviemacca
