yes theres sound, now there isnt?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by raiz, Aug 11, 2005.
  1. raiz
    raiz
    hello all, hope you can help?
    im using a cannon mv730i to capture footage via a helmut cam.
    This footage has sound both on playback and viewed through tv,BUT when transfered to pc i loose the sound?
    There is also normal recorded footage on the same tapes which have sound before and after transferring.
    im using windows movie maker to capture this footage.
    :smashin:
    CHEERS ALL
    RAIZ
