Yes or No ? Watching a Setanta programme for 1-30 mins during run-in ?
Discussion in 'Plasma TVs Forum' started by The_1_And_Only, Jan 12, 2008.
  1. The_1_And_Only
    The_1_And_Only
    Nov 8, 2007
    207
    +15
    My parents got their panasonic TH42PZ70 delivered this morning and my old fella is a big Man United fan, would it be wise to watch Man United v Newcastle on Setanta later during the run in period as the setanta logo will be on display for 1 half hours during the game.
    I have reduced all their settings on the tv to low contrast and brightness etc and its in cinema mode.
    Am i being over cautious or is this a big No No ?
  2. The_1_And_Only
    The_1_And_Only
    Nov 8, 2007
    207
    +15
    Anyone have an opinion, this games kicks off at 5-15 on Setanta ?
  3. stranger
    stranger
    May 29, 2003
    2,513
    137
    Manchester
    +856
    If you are worried you could use 'zoom' a few times throuughout the match to shift the logo.
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Are you serious? What have you been reading! You've bought a telly, not an ornament! Watch it, that's what it's designed for. Your settings are probably too low if you are that paranoid. Half way should be fine, get yourself a setup disc and calibrate it, it will be on safe settings if you do that.
  5. jameshardy89
    jameshardy89
    Jan 3, 2008
    I would say you're being over-cautious.
    although I'm sure there will be those who disagree.
  6. YellowSphere
    YellowSphere
    Dec 2, 2007
    4,448
    103
    +471
    On a related note, which setup discs do you recommend?
  7. Jazzy639
    Jazzy639
    Dec 28, 2006
    582
    +20
    Ive heard any THX Certified DVD has a THX setup
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Yes, in the languages section usually. That's surprisingly good for basic contrast, brightness and sharpness, which are the pertinant settings for prevention of screen damage. With the use of the THX optimiser, your chances of screenburn are vanishingly small, even gaming. Your brain will burn before permanent screen damage.
  9. SlinkDaddy
    SlinkDaddy
    Jul 16, 2006
    2,952
    Essex
    +299
    Ie any star wars DVD
  10. The_1_And_Only
    The_1_And_Only
    Nov 8, 2007
    207
    +15
    We watched the game and it seems fine, its just your over cautious when its a new plasma television especially with it being your parents set. I have to say the football seemed amazing in quality on the 42PZ70 and thats taking into account that it was on setanta and they don`t have the best signal feeds.
