Yellow patch on screen
Discussion in 'General TV Discussions Forum' started by revenot, May 7, 2007.
  1. revenot
    revenot
    May 7, 2007
    14
    4
    Motherwell
    I was wondering if anyone can tell me why i am getting this yellow patch on the right hand side of screen.
    I have got a Toshiba 42WH36 rear projector tv which is still under warranty till 2009 so if it is a major problem i can get it sorted under my warranty.
    I was also wondering if a small surround sound speaker can cause this yellow patch as i have one next to the tv but i dont get the patch on the left hand side where the other speaker sits.
    I would really appreciate your help thanks.
  2. scooby do
    scooby do
    Dec 11, 2002
    2,058
    48
    +95
    It will not be the speaker, could be the coolant on the CRTS that has aged perhaps
  3. revenot
    revenot
    May 7, 2007
    14
    4
    Motherwell
    Thanks for your reply scooby do.
    The tv is only 3 years old so would the coolant on the CRTS still be aged and should i call my insurer to get it sorted.
  4. scooby do
    scooby do
    Dec 11, 2002
    2,058
    48
    +95
    I would definatley call them, especially if the problem has developed recently. It isn't that you now have a test disk with colour fields that are bringing you to notice the problems. Sometimes ignorance is bliss. CRT RP if you have a good one are hard to beat but can display problems that show up during intensive testing.
  5. MQUIN SKYWALKER
    MQUIN SKYWALKER
    Mar 1, 2005
    590
    LEIGH,LANCS
    +25
    HAD THE SAME thing but red on a brand new one from currys 2 years ago,took it straight back,lady pretended she couldnt see it until we saw a yellow spot on the one in store in the same place,seems like a fault with this set,crap tvs will never have another tosh
  6. revenot
    revenot
    May 7, 2007
    14
    4
    Motherwell
    Thanks for the replys guys.I will give my insurer a call and see what they will do about it.
    Engineer booked for Saturday 19th May.
    Any questions i should hit this guy with would be appreciated.
  7. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    This is a typical convergence problem on these types of set. I have had a couple and one was so bad that all the writing going up the screen at the end of a film was yellow.
    A sevice menu calibration will fix it. Whn you bring up the crosshatch screen you will see that the green and red grids will be ok (Making yellow) but the blue grid will have drifted.
    It makes a whole lot of difference doing a calibration like this from the service menu to the whole picture.
    If you do take this on do not alter the green grid. This will affect the geometry!!
    Plenty of tips and instuctions on this if you do a search via this forum or google it.
    Regards
  8. revenot
    revenot
    May 7, 2007
    14
    4
    Motherwell
    Thanks for the reply Mark.
    I did go into the convergence menu and i have only got red and blue cross grids which you have to fit over a white cross so all you see is the white which means your picture should be perfect.(Yellow patch still there).
  9. Shady Deal
    Shady Deal
    Sep 5, 2001
    435
    Wiltshire
    You need to do a "service menu" convergence. This is not the same as you are trying.
    Search the forums on how to do it, well worth it!!
    Regards
  10. revenot
    revenot
    May 7, 2007
    14
    4
    Motherwell
    The enginner has checked out my tv and he has written it off.I now have £990 worth of vouchers to spend at comet on a new tv.
    I am looking for suggestions ppl on a new tv should i go plasma or lcd and what is the best tv out there.
    Thanks.
  11. scooby do
    scooby do
    Dec 11, 2002
    2,058
    48
    +95
    The 55 inch SXRD would fit the bill nicely if comet can get hold of one for you.
  12. revenot
    revenot
    May 7, 2007
    14
    4
    Motherwell
    Thanks mate but i have heard sony have took the SXRD off the market.
    I was actually looking at getting a good flat screen rather than another rear projection tv.
  13. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,733
    Somewhere in South Yorkshire
    +6,309
    I suggest you move your attention to the Plasma and LCD forums, then. You'll get different answers in each, from which you should be able to distil out something that will help.
