YDL now with WI-FI support!
Discussion in 'Computer Software & Operating Systems' started by waring192, May 2, 2007.
  1. waring192
    waring192
    Apr 26, 2006
    1,912
    Cumbria
    +180
  2. waring192
    waring192
    Apr 26, 2006
    1,912
    Cumbria
    +180
    Carnt find a mirror with it on as yet :mad:
  3. littlelio
    littlelio
    This is good news! I hope that all other distribution can also support wifi after YDL did it!
  4. waring192
    waring192
    Apr 26, 2006
    1,912
    Cumbria
    +180
    Managed to do it! Its fully working! Bit tricky for me as being a linux newbie!
  5. KevB_UK
    KevB_UK
    I've been waiting for this one!
    I've managed to install the new kernel and I am able to add a new wireless connection into the network setup window, but I just couldn't get it to connect.
    It was early in the morning when I tried it though, was there anything out of the ordinary in the setup you needed to do?
  6. waring192
    waring192
    Apr 26, 2006
    1,912
    Cumbria
    +180
    wep thing has to be added with 0x at the start eg "0x435tr6774d"
    Same channel as router?
  7. KevB_UK
    KevB_UK
    Yep wrong channel! Got it working fine now thanks.
  8. iddqd
    iddqd
    Jan 8, 2007
    2,024
    63
    +179
    So what advantages will this now give?
  9. waring192
    waring192
    Apr 26, 2006
    1,912
    Cumbria
    +180
    You can connect wirelessly to the internet while using linux, instead of having to run cat6 cables everywhere!
  10. sickofusernames
    sickofusernames
    Jan 22, 2006
    171
    Buuuurmingham
    Yep, late night for me too trying to set it up. I keep getting -
    "Error for wireless request -Set Bit Rate *8B20 (or 8820, can't tell!)
    SET failed on device ETH0:Operation not supported.
    Here's my setup, am I doing anything wrong do you think? I have a Dlink ADSL router with WPA-PSK key btw -
    Mode :Auto
    Network SSID :Auto
    Channel 6 (which my router is on)
    Key 0x(plus my WPA key)
    or is this where i'm going wrong and the Wifi only connects using WEP? Please, somebody help me...... :confused:
  11. sickofusernames
    sickofusernames
    Jan 22, 2006
    171
    Buuuurmingham
    I seem to have answered my own question, having searched on the YDL forums it appears WPA isn't currently supported hence no connectivity - only Open or WEP wifi at the moment....think i'll wait until they have sorted it
  12. waring192
    waring192
    Apr 26, 2006
    1,912
    Cumbria
    +180
    i think the mode has to be on manual also, carnt remember for sure though.
  13. sickofusernames
    sickofusernames
    Jan 22, 2006
    171
    Buuuurmingham
    Ok, being the curious egg I am I decided in the end to try connecting using WEP just temporarily to see if WiFi works.
    It did, (although it couldn't see any external websites) and now it doesn't, still can't reconnect! - and I didn't change anything...
    I don't understand why, it's so s**t that i'm not going to bother now unless somebody can produce a writeup on how it works 100%, and as for YDL's bulletin on the WiFi connection - well that just sucks.
    The PS3 can connect fine to my router as when I rebooted into the game-os I was logged in to the PSNetwork using WEP.
    Frustrated!
