SeanBrothers
If you want, I can estimate this for you if you give me the following:
- Distance to LCR speakers from MLP
- Room volume (ft3)
- Maximum listening level with a reference source (e.g. DVD, Blu-ray) - this assumes your system is calibrated to 0dB volume being reference level, not all are.
- Model of AVR/amp
I assume your quoted speaker specs are for the LCR speakers. If not, I’ll need those too.
Thanks for looking into this @Mr Wolf!
AVR: Denon AVR-X3700H
Power Amplifier: Adcom GFA-545 II (100 WPC into 8 Ω applied to front LR)
Front LR: Elac Uni-Fi UF51 (Nominal impedance: 4 Ω; minimum 3.4 Ω; Sensitivity: 85 dB at 2.83 V/1m; Distance: 2.34m)
Center: Elac Uni-Fi UC51 (Nominal impedance: 4 Ω; minimum 3.4 Ω; Sensitivity: 85 dB at 2.83 V/1m; Distance: 2.31m)
Surround L: Elac Uni-Fi UB51 (Nominal impedance: 4 Ω; minimum 3.4 Ω; Sensitivity: 85 dB at 2.83 V/1m; Distance: 1.50m)
Surround R: Elac Uni-Fi UB51 (Nominal impedance: 4 Ω; minimum 3.4 Ω; Sensitivity: 85 dB at 2.83 V/1m; Distance: 1.59m)
Rear Surround L: Pioneer SP-BS22-LR (Nominal impedance: 6 Ω; Sensitivity: 85dB/2.83 V/m; Distance: 2.79m)
Rear Surround R: Pioneer SP-BS22-LR (Nominal impedance: 6 Ω; Sensitivity: 85dB/2.83 V/m; Distance: 2.88m)
Top Front L: Polk OWM3 (Nominal Impedance: 8 Ω; Sensitivity: 89dB/1 W/m; Distance: 1.74m)
Top Front R: Polk OWM3 (Nominal Impedance: 8 Ω; Sensitivity: 89dB/1 W/m; Distance: 1.71m)
Top Rear LR: Polk OWM3 (Nominal Impedance: 8 Ω; Sensitivity: 89dB/1 W/m; Distance: 1.89m)
Subwoofer: Velodyne DD12 (Amplifier output: 1250W RMS, 3000W peak; Distance: 2.67m)
Room: 1600 ft3
Volume: Sometimes as high as -18db
