Yammy rxv630
J
jimmylad
Does this amp give you 2x seperate channels to play in another room ?? & if it does can you have the 5.1 on as well as the 2 stereo channels ?
Also where is the best price for this kit ?
TIA
Jim
B
bob007
Don't think this amp has multiroom funtion, but you could use the A/B speaker selector, "A" for the set up in the front room 5.1 and "B" for a stereo pair in another room. Won't play different sources in the different rooms though. If you choose to do this check whether A/B can be used together in this way, don't want to damage the amp, I know they can be used together when bi-wiring, but this is a different application. :)
