Yammy 620 "ticking" - more info and help please!
Discussion in 'AV Receivers & Amplifiers' started by huntere, May 31, 2005.
  1. huntere
    huntere
    Dec 30, 2004
    1,583
    63
    Perth, Australia
    +241
    Guru's
    Posted a while ago about "ticking" through my KEF eggs from a Yammy 620.
    Well have finally got the back of the cabinet off and done some tests. Basically happens on all channels and doesn't matter whats connected and whats not - therefore I assumed amp is "problem".
    PLayed further and found ONLY get this effect when using "effect" modes. i.e. with effect off sound is perfect, when switched on (any effect) I get this ticking (sounds a bit like a CD spinning and cathing something).
    Anyway question is - is amp or processing ciruitry stuffed? I have Richer sounds 3 year warranty/cash back option so I do send for repair or chop in and get a 750?
    :lease:
    Thanks in advance.
    Evski
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Sounds like a fault in the DSP section.
    Can't help you though with the question if you want it repaired or replaced ...
  3. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    I had a similar fault on my 620, it was when I got better and more demanding speaker. Changed to a 2500 and problem solved, never had the problem on my cheaper on my cheaper yamaha speaker set.
  4. huntere
    huntere
    Dec 30, 2004
    1,583
    63
    Perth, Australia
    +241
    Ok
    The decision as..........
    I bought a 757 (couldn't get a 750).
    Veyr very pleased. All I wanted was to fix the "ticking" which it did admirably - but pleasantly suprided by the better performance and "definition" of sound. Wasn't expecting that as thought there wouldn't be hige difference between 620 and 757 0 or maybe the YPAO did a better job that I had manually!
  5. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    Glad the problem is solved :)
