Yammi rx 630
Discussion in 'AV Receivers & Amplifiers' started by Desperado, Sep 26, 2003.
  1. Desperado
    Desperado
    does someone now how to set this Amp to 6.1 ican get the Center back up and running
    anybody?
    Pls lmk
  2. Family Guy
    Family Guy
    Is there a noise coming from the surrond back channel when you run the test tone through it? If there is, to engage it whilst watching a movie, you need to press EX/ES on the remote. It'll come up on the display "off" - "auto" - "Matrix 6.1". The surround back channel will then be on...it will only come on aotomatically if the disc is flagged. There is no way to leave it on all the time either as there was with the Pioneer.
  3. avanzato
    avanzato
    Jan 21, 2003
    1,881
    Norfolk
    +61
    On my AX630 you also have to turn on the centre rear in the speaker setup menu.
