Yammaha AX-1 gone funny
Discussion in 'AV Receivers & Amplifiers' started by Neil69, Jun 29, 2003.
  1. Neil69
    Neil69
    Jun 8, 2001
    314
    9
    Leigh
    +17
    :suicide: :suicide: HELP please!!! I have a Yamaha AX-1 with a funny fault. The left front channel doesn't work with ANY digital inputs. It's OK with analog phono inputs. I had a problem like this 8 months ago. I rang Yamaha & explained the fault. The bloke I spoke to was baffled. He told me to ring my local Yamaha agent to let them have a look at it. Naturally, they found no fault as when they plugged a fibre optic cable into it from a DAB unit & it worked. So I thought nothing of it & brought it back home, as it worked, until now. Has anyone had this kind of fault with an AX-1? Any suggestions will be helpful.
    Cheers, Neil.
    :suicide: :suicide: :suicide: :thumbsdow :thumbsdow
  2. nathan_silly
    nathan_silly
    If you've tried using all the digital inputs (and none work) -optical and coaxial? and the analogue inputs work I would probably guess the left front channel DAC, or something along the digital left front channel PCB path is faulty.
    I take it you've changed the left & right speakers over and checked speaker cable, balance, channel level etc?
  3. Neil69
    Neil69
    Jun 8, 2001
    314
    9
    Leigh
    +17
    Cheers Nathan for posting your reply. I have tried everything bar dropping it from a great height!!!!!
    Neil
  4. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    The channel DAC will (normally/usually) be employed in both analogue and digital stages unless true bypass is engaged.
    Steven
  5. BabylonP
    BabylonP
    Dec 10, 2002
    98
    11
    +5
    This may be a long shot but I had a channel go on my old AX1. The problem was the preout terminals on the back. It was a known fault that in some cases the relay would close as if you were using a seperate power amp on the channel, the net effecti is that the onboard power amp gets disconnected. I had to have all my imputs upgraded at a Yamaha dealer.
    I was told you can reset the fault by pushing a plug in and out of the terminals a few times this resets the relay.
    As I said a long shot
    Phil
  6. Neil69
    Neil69
    Jun 8, 2001
    314
    9
    Leigh
    +17
    Thanks, Phil. I had all the pre ins & outs changed about a year ago. I've tried connecting them all together again but I've had no joy.
    Cheers, Neil
