Yamakawa in 1080i component mode - can someone try it
Discussion in 'Blu-ray & DVD Players & Recorders' started by z5461313, May 4, 2004.
  1. z5461313
    z5461313
    Sep 18, 2001
    1,635
    +235
    The Yamakawa 365 can output 1080i in component mode
    Could someone try this - output to a projector - and see what the picture quality is like please?
    To an AE300 would be great
    This picture should theoretically give the best one possible if you read what they are saying over at the avs forum
    It should beat the denons and panasonics that only do normal 576 progressive
    And component output at this resolution may look the same as DVI connection
    Thanks alot
  2. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    I couldn't tell you about component or a projector, but on my screen through DVI the picture appears to be best but on slow pans it jerks so I leave mine on 720p.
  3. Family Guy
    Family Guy
    That's correct - the 1080i is output in 60hz. Fine when playing a R1 disc, but very noticeable jerks when panning on R2 discs.
    I speak from experience BTW...
  4. z5461313
    z5461313
    Sep 18, 2001
    1,635
    +235
    Thanks for that
    The jerkyness is not wanted. Have to discover a DVD player that is smooth at this rate
    The Zenith in the USA seems to be ok but is only a USA product
