Yamakawa 365 and component connection question
Discussion in 'Blu-ray & DVD Players & Recorders' started by retrof, May 19, 2004.
  1. retrof
    retrof
    Feb 28, 2001
    158
    +14
    I'm wondering whether to use a component or DVI connection to my Z1 from the 365. Is anyone using the 365 via component? - if so, what adapter did you use for the SCART socket to get the component connection?
    Can I use a DVI to VGA adapter to connect it to my Z1's VGA input? if so, what adapter do I need, and how does it connect? (in other words, do I put the adapter on the 365 and use a VGA cable, or put it on the Z1 and use a DVI cable?)
    If I connect DVI to VGA on my Z1, could I use custom resolutions to get 1 to 1 pixel mapping with my Z1?
    Would this DVI to VGA connection produce the best image, or would it just be the same as a high quality component connection?
    Thanks in advance,
    -rf
