Quantcast
Yamakawa 365 and AE100 help
Timh
I am thinking of going for the Yamakawa dvd player and connecting it to my Panasonic AE100 projector but I am sure the Yamakawa does not have componant out. Does it output componant from the scart socket? if so where would I get an adapter from? Or is it possible to connect via dvi to vga?
If anyone uses the Yam via componant could you give me your views on picture quality.
Tim
SamirP
Yes it outputs YPbPR via scart.
TVcables do a scart to component cable
The Dvi only outputs dvi-d signal
I only used mine for a short time (2hrs) before i got my dvi cable, but it produced a very good pq at 720p :D
Timh
Thanks for the info Samir :)
Has everyone that ordered the Yam from Germany been stung by Customs, if so how much was it.
Tim
gjc-ortho
Ordered form Germany; no problems with customs. Better service that most UK online sales!
Cheers all
ebury
I thought any goods purchased in Europe were exempt from customs,or am i talking bull'??
Singh
sort of correct... goods imported from the EU have no tariff charges
F
Family Guy
Dixons do a scart to component cable for £12.99. 1 metre long, and ideal to run to the amp and then from the amp to the PJ/plasma...
Timh
Thanks all, i will keep it on my short list :)
simey
ebury, you are right, there are no Customs Duties between members of the EC. Although if you're not VAT registered and able to give the supplier your VAT number then they should charge you their domestic rate of VAT. (nothing extra to pay when the goods enter the UK though).
popeckia
I order the Yamakawa 365 from computeruniverse.net. Was a bit of a pain as you have to fax credit card and second signature, and not everything on the site has yet been translated to english.
In addition, my player broke after 1 dvd :( I get no video output and no audio, and after discussion with Yamakawa it appears to be dead.
CU said they would pay for return shipping and would in fact come and pick it up, which is pretty good service from Germany I think.
Incidentally, the 1 film watched over DVI looked great with AE300... and much less hassle than my rather fragile HTPC. That said, if I was going component I would probably get something else... it's not exactly robust build quality, and without the DVI how good would the picture really be into the AE100?
alancolledge
I didn't have to do that! I have a Visa card and did all my ordering over the net. The player came a week later...:confused:
