Yamaho DSP-E800 advice needed plz
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by NinjaKi11a, Sep 10, 2003.
  1. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Are there any plans for a new verision or something similar, perhaps in 6.1, for this processor? I'm abit stuck here with a NAD C170 amp - I am determined to stay with a dedicated audio amp, but am wary about buying a four year old processor. None of the other processors suit my budget - in fact I'm unconvinced they're worth it at all.
    Would it be worth waiting to see what Yamaha do or should I bite the bullet and buy the DSP-E800. If so, what kind of price should I be working the salesman towards (while I buy my B&W 602s, centre speaker and HK DVD25).
    Cheers.
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Look at buying any surround amp and as long as it has pre-outs it will do the same job as a DSPE-800.
    I did have a DSPE-800 for a couple of years and it was pretty good, but unless you find 1 really cheap now a newer amp will probably be better value with 6.1 and PLII.
    Slingshot
