YamahaRX-V650 undesired delay in STRAIGHT
Discussion in 'AV Receivers & Amplifiers' started by univox, Jan 26, 2005.
Tags:
  1. univox
    univox
    bought on 25.12.2004 a piece of your Yamaha RX-V650 receiver , convinced, that this is one of the best products of this class. Unfortunately, I found a very unpleasant effect, using analogue inputs. It could be easily observed, if you connect a TV set to any analogue input and listen to the program, better speech, simultaneously from the TV's and receiver's speakers at even volumes and STRAIGHT mode.There a sensible ambiance effect could be heard, due to delay of maybe 5-10 mS (enough to be noticeable), entered by the receiver. I think that there is the ADC section to blame,because it has has not been observed using digital inputs or, of coarse, in PURE DIRECT mode. If you listen to ordinary audio sources, other than TV or ones with their own speakers , this effect is hard to be discovered, but I use the device as a monitor amplifier during the home studio guitar recordings. By the reason, that playing guitar, I exactly know when the string is hit and the sound starts, which is not that way when you listen to CD or other audio source, the sound comes noticeably later from the speakers. It makes the use of the unit for this important to me purpouse impossible.On other hand, everyody knows what STRAIGHT means and there must no delays or any noticeable changes be observed normally.The things get worst when I try to play or record along the rhythm or other track,because I must add to my right hand movements some delay to compensate this one, entered by the receiver to synchronize the tempo between new and old track.Please,try to do it yourself:)
    I wanted to check if the problem is not personal and persists with other pieces of this model before I write you. I made the TV test with two more my friend's receivers RX-V650 and the result was the same. It makes me think, that there some constructive deffect(maybe software) persists, and probably with the 550 and 750 series too,if the input section is the same.
    I had a SONY STR-DB790 with no any problems with delays, but sold it to buy Yamaha. Now I'm in three minds what to do-to keep the Yamaha, if they could fix the problem,or to replace it with Sony STR-DB795 or Denon 1905.It's very important for me the unit to play well in stereo.The speakers I'm intended to use are HECO Concer 15.Waiting for advices.
  2. Magnet & Steel
    Magnet & Steel
    Jan 14, 2005
    108
    16
    my dsp-ax750 also has a slight delay effect if i accidentally leave the tv speakers on, but its normal, my last amp did this too. its not a fault and if i understand your post correctly, you are using the tv speakers as monitor for your guitar? if so that isnt an ideal setup and is no fault of the amp. a friend of mine has the 650 and his is the same when fed from a sky box, but he just turns the tv speakers off and all is fine.
