Yamaha
Discussion in 'AV Receivers & Amplifiers' started by IanW1977, Dec 31, 2002.
Tags:
  1. IanW1977
    IanW1977
    Dec 30, 2002
    4,542
    West Midlands
    +487
    Thinking of getting the HTR5540RDS, but have seen it in a package with speakers (HTIB 45)
    Is it worth getting the package or the amp alone and getting other speakers ??
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    hi ianw1977
    you don't say what your budget is for your speakers .You can get the receiver for around £210 the nsp220 speaker package retails around £140 the hti-b45 around£320 a saving of £30 .Ian i started off with this package the receiver being the better piece but as a starter kit you could do a lot worse. If you can afford it buy the 5540 and go for a mission Mseries speaker package again good value then your on the first rung of the upgrade ladder . good luck gonzo;)
  3. IanW1977
    IanW1977
    Dec 30, 2002
    4,542
    West Midlands
    +487
    Budget Erm
    Well Max of £400
    So Say £190 for Speakers and Wiring
    Any ideas mate ???
  4. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    hi ian
    have a look at the nsp320 speaker package from yamaha should be £250 but from unbeatable.com £197 .You can check the system out on the yamaha web page would be a decent match for the receiver for £200 that is your budget its not a bad buy.
    cheers gonzo.:)
