yamaha z9 - connect speakers to front B channel
Discussion in 'Home Cinema Speakers' started by namelessrsa, Apr 25, 2005.
  1. namelessrsa
    namelessrsa
    I would like to connect 4 speakers onto the front B channel, the speakers are 8 ohm. How can i connect the four speakers ?
  2. namelessrsa
    namelessrsa
    can't anybody give me some advice ?
  3. recruit
    recruit
    Do you mean connect 2 speakers to the A terminals and another 2 the B set of terminals? rather than just to the B set as i do not think this is possible.
  4. namelessrsa
    namelessrsa
    already have speakers on A terminal, want to put 2 set's of speakers onto B terminal.
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Just squezze the wires into the B terminal or make yourself some splitter / Y-adapter cable.
    However note that running the front channels with 6 speakers may not be a good idea since it will put a lot of load onto the amp.
